Torque on an Operating Shaft
I am a structural engineer assisting a client in determining the cause of a shaft failure. We normally strain gage components, but this is an inaccessible rotating shaft. I can analyze the shaft and key, but need to determine the shaft torque. I have limited motor info so far (25 HP, 1200RPM), though the in service speed is 7 RPM. I have the formula T=HPx5252/RPM. It can't be that simple to determine the in service torque, is it? Do I need a chart of torque vs speed for the motor? I'll spend more time researching, thought I could get a little insight here as well. Not looking for specifics, just to be pointed in the right direction.
RE: Torque on an Operating Shaft
Well, yes and no.
Just because the motor's nameplate says "25 HP" doesn't mean that it's producing 25 HP at your operating condition.
You'll be able to get motor curves from the manufacturer (although it's a good bet that they didn't bother to develop them a 7 rpm).
At any rate, you'll need to measure input voltage and current.
Johnny Pellin
Yeah the formula you have will give you the maximum torque attainable excluding losses ie friction etc for 25HP.
There are clues as to the type of failure of a shaft by looking at the fracture surfaces as mentioned by others and some clues are given at this site:-
ht
Now from your post I calculate the torque to be about 25000Nm which is a fair old torque.
To expand on JJPellins comments on failures, a failure at 45 degrees to the shaft centerline, can be caused by fatigue cracks growing perpendicular to the max principle stresses, generated by a shaft under torsion or by a brittle failure in a material that is weaker in tension than in shear.
A shaft fracture at perpendicular to the shaft centerline is usually indicative of a shear failure.
If you can post some pictures that would be good.
desertfox
ISZ
The problem that I see with your formula is not that I think the formula is incorrect -- it is not. Rather, I think it is the wrong formula. A motor which produces 25 hp at 1200 rpm will not put out 25 hp at 7 rpm. What type of motor is this? If it's an induction motor (almost guaranteed if it's 25 hp), then you will NOT get 25 hp when you're running it at 7 rpm. When you run induction motors (and most all electric motors) below the nameplate speed, they produce a torque at or usually well below the torque produced at the motor's nameplate speed. So if you determine the torque produced at 25 hp and 1200 rpm, you're going to be dealing with that torque or less (probably a WHOLE LOT less) at 7 rpm.
But when I step back from the problem and look at what you're asking, I think that we're missing something here. My first question to you would be: is there a gearbox between the motor and the 7 rpm shaft?
Engineering is not the science behind building. It is the science behind not building.
"Well, yes and no.
Just because the motor's nameplate says "25 HP" doesn't mean that it's producing 25 HP at your operating condition."
Ok, but the motor IS capable of 25HP, so should this not be used a upper design limit?
"If you have an important point to make, don't try to be subtle or clever. Use a pile driver. Hit the point once. Then come back and hit it again. Then hit it a third time - a tremendous whack."
Winston Churchill
Also the motor might well not be running at full load but in the light of no other information we at least know its maximum torque available.
desertfox
The shaft is apparently failing at much lower power, so it's probably a fatigue failure, not an overload.
25*198000/pi/1200 = 1313 in-lbs.
The gearbox increases that to 92,332 in-lbs.
The sprockets increases the torque from the gearbox to 320,084 in-lbs on the shaft in question.
In addtion to the torque on the shaft there is an overhung load caused by the chain tension whose value depends upon the pitch radius of the 52 tooth sprocket. The overhung load will add a cyclical bending stress to the shaft in addition to the torsional stress it sees.
