Need company to help design/prototype u-neek gate valve
Working on a very u-neek 7/8" gate valve and need a company to help finalize design and prototype, and possibly mass produce.
Thanks for your time and any help brothers.
Valve: - very low psi
-light weight aluminum
-single hand held and operated
-on/off switch not lever
RE: Need company to help design/prototype u-neek gate valve
Mike Halloran
Pembroke Pines, FL, USA
Low pressure, 7/8" aluminum body gate valve . . . what else do you need? Seat material, body casting/machining design, stem & seals, actuator?
This valve is very light weight and very light duty used for non-corosive fluid transfer.
Let's try this: in my member name, take out the "1" and put "_i", then put another underscore after the "n". That will be my address at yahoo.
