determining critical particle velocity for a marine structure
I have question on determining critical particle velocity for a concrete wharf, or the natural frequency of the structure. Blasting operations will be near the structure and need to provide a upper limit which a blaster cannot exceed. Is there a proven method which I can quickly calculate or understand. To better aid your response, the following parameters are:
Structure to Remain:
The Wharf is supported on 24" Square Concrete Bearing Piles. All piles were driven to refusal to a depth of 45 feet. The structure has no batter piles. The uniform Live Load for the structure was design to be 800 psf.
Structure to Remove:
The derelict structure is 80 feet waterward from the face berth, and is submerged to a depth of 35 feet and is 15 feet deep.
Geology:
The area is comprised of Clay,sand, sandstone, Limestone. Both structures are resting on limestone.
Any hints, suggestions, books, programs will be very useful and handy.
V/r
Geology:
V/r
RE: determining critical particle velocity for a marine structure
Here is a pretty good thread
h
