pro E line weight problem/pen assignments
So, i know how you can go into the options, and change pen1_line_weight value, but what i need to do is group the curve (darker blue) and the white geometry lines into different pens. Is there a way to do that? we use curve colors for our dimensioning, and we need the geometry lines to be thicker. How can i achieve this? and i know people tell me to go into config.pro, but when i search for config.pro, there are a lot of those, which one is the right one??
RE: pro E line weight problem/pen assignments
I would suggest that you delete the extra ones, unless pro engineer is directed to read them, they would probably not be read anyway.
Hydromech
Fighter Pilot
Manufacturing Engineer
pen_table_file <path to file>
Fighter Pilot
