Which states require passing the Structural I and II exams?
I heard that in some states you cannot practice structural engineering unless you passed the Structural I and II PE exams. Other states allow you to practice as long as you have a PE and are competant in the field you are practicing in. Which states require the Structural I and II?
RE: Which states require passing the Structural I and II exams?
Check this article. Each state has it's own regulations and keep changing over time. And, so it is a good idea to check with the state boards you are trying to get licensure from. But, this article should give you a good idea of the requirements of most of the state boards.
http://www.ncsea.com/downloads/groups/StructuralEngineeringRegulation.doc
Also, check out the article on the new 16 hour structural exam that is going to replace SE-1 and SE-2 exams beginning next year.
http://ncsea.com/downloads/groups/licensing/2010_16-Hour_Strl_Exam_article.pdf
Hope this is helpful.
You can check out the NCEES website as well.
