Stringers to Frames attachments
Can anyone help me to evaluate the stringers to frame forces due to the internal operative pressure?
Thanks.
P.S. no BDM procedure, please.
Thanks.
RE: Stringers to Frames attachments
The trick is determining how much of the hoop stress is carried by the skin and how much is carried by the frame. Tear straps and shear ties complicate the problem even more.
If you wanted a quick and conservative way I would assume all the hoop stress is being picked up by the frame and multiply your delta p by the stringer/frame area (mid frame to mid frame by mid stringer bay to mid stringer bay).
