Mechanical Routing
Mechanical Routing
This is for NX6 users.
I am curios how other users are doing Mechanical Routing. I usually use create linear path and just pick a point to start from and use the Dynamic Axis or one of the other options in the pull down. I go back and add the radius or bends after just in case a that corner is not too small for the radius. We are trying to come up with a best practice process for routing tubing and any help would be appreciated.
Pretengineer
Pretengineer
RE: Mechanical Routing
As an aside give a hearty THANKS to your management for getting that license. It vastly beats using sketch and datums to route spaghetti.
