Current Transformer Question
I have a bushing current transformer on a transmission circuit breaker. If I short the current transformer and ground it, does current still flow through the closed loop?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Current Transformer Question
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
What we were wondering was if we took a ammeter if we could test the current near the CT to see if this was the case. The ammeter would be a wrap-around type.
Make sure you don't accidentally open circuit the CT secondary as you are getting things fixed up.
David Castor
www.cvoes.com
When the CT is shorted, the resistance is very low so the I2R is very low.
I lost a good meter on an open CT. Someone cut the leads in a wire bundle behind the control board. I was trying to locate a particular CT so I took a voltage reading across the relay and was behind the panel checking voltages across CTs looking for a match. (Yes, I admit it, I was trying to get lucky.)
I measured one CT and my meter made a buzzing sound and never worked again. After safeing the CT I found the leads cut in a bundle. I thanked God that I hadn't been running my hands near the cut ends following a conductor.
I was sure glad to go home that day.
The joys of working in the third world.
Bill
"Why not the best?"
Jimmy Carter
I lost some good underwear in similar circumstances.
You stated,
"We actually have a CT going to a relay but the relay is reading zero amps and zero degrees so we are thinking that a shorting screw was left in place somewhere."
Depending on the type of relay, don't forget to check the case. Over the course of time I have found several mismatched relay/case combinations.
Of course if you are using a clamp around type Amprobe to measure current then a defective or mismatched case will not be your problem.
Also check for a stray ground in the wiring. If the CT polarity side wiring (X1) is inadvertently grounded, it could shunt the current to the relay.
