ASME Sec VIII, Div 1 Single U-1 form for multiple vessels?
Is it allowed for a manufacturer to fill out and submit a single U-1 for (aka Manufacturer's Data Report) form to the customer for multiple pressure vessels, if all of those vessels are identical?
RE: ASME Sec VIII, Div 1 Single U-1 form for multiple vessels?
I think you can do it if all of them manufactured and tested in the same time (as a batch). There is serial number to identify each of them. AI should visit to witness, sign on U-1 (where all units should be listed) and date it.
curtis
InspectorJohn,
Yes, it is allowed if the vessels are completed on the same day and all the requirements of UG-120(a)(1) are met.
Curtis: and NB numbers if the items are registered. acceptance of the AIA, AI are needed,(some AI's ill not allow it for a reason. depends on the size and quantity of the production of vessels.
  UG,120,a,1 shall be accepted at time of ASME review
  to take effect.
genblr
Very helpful, thanks to all for your replies.
