Restriction/Flow Orifice Plate Dimensions
I'm looking for info/spec numbers for the manufacture of Restriction/Flow Orifice Plates.
I've found lots of useful websites with sizes/dimensions for imperial sizes(typically 2" pipe ANSI 150 & upwards)
I'm looking for the metric equivalent in DIN/PN pipe size/class.
Thanks.
Thanks.
RE: Restriction/Flow Orifice Plate Dimensions
Cheers,
John
Thanks for the reply.
I'm looking for actual dimension details for O.D.'s of the metric restriction/flow orifice plates. There's lots of info for imperial size on the web but, I can't find details for metric.
I've put a call in for ISO 5167 and will look at that.
My other alternative for O.D. sizes would be to look at metric gasket dimensions.
Many thanks.
