Blast Design - Pressure, Duration, Impulse
Does a higher impulse always control blast design? Or should pressure and duration be considered more in depth?
Example: Here we have two blast scenarios. Let's assume for this case that the member in question is a simply connected wide-flange member.
Scenario 1:
p1 = 1.0 psi
t1 = 50 ms
Scenario 2:
p2 = 0.5 psi
t2 = 100 ms
Obviously, impulses for the two cases are equal. Does this mean that either is an acceptable design scenario?
What if d2 = 105 ms? Would the larger impulse control or does the longer duration (t2) have a more significant effect due to rigidity and stress-strain of the material with respect to time?
Does natural frequency play a part in choosing the design scenario?
Does material play a part?
Scenario 1:
p1 = 1.0 psi
t1 = 50 ms
Scenario 2:
p2 = 0.5 psi
t2 = 100 ms
RE: Blast Design - Pressure, Duration, Impulse
Duration of impact is related to natural frequency. The impact duration closer to the natural frequency will give the worst case, isn't it?
Various material could change the damping ratio (C), mass (M), and stiffness (K) of blast structure, they govern the dynamic properties of the blast wall?
Damping is also important, which dissipates the impact energy.
