Surface texture on Acme threads
Can anyone reccomend whether they would suggest a surface finish on the thread face of an ACME thread.
The problem i have is that on occasion the machinists we use produce some screwed couplings where the thread face has a really rough finish.
Kieran
Kieran
RE: Surface texture on Acme threads
However, I'd check into the actual ACME thread standard to see what if anything it says before adding a separate/additional requirement.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
