EMI shielding in Space
   Hi all,
I would like to know more about EMI Shielding.
-    What are the main parameters of an electromagnetic wave (frequency/wave length, ...)?
-    What are the typical EM waves received by a space satellite?
-    How to calculate the thickness of the shielding?
-    The perimeters of holes in the shielding must be much smaller than the wave length, what is the order of magnitude of this difference?
Gregoire
RE: EMI shielding in Space
All good questions, but you should consult a qualified engineer or a good textbook.  This is not something to decribe in this type of forum.  "Space Mission Analysis and Design" would be a good starting point
TTFN
Thanks, I'll start with that!
here's a link to a cutoff waveguide calculator. It'll at least show you the size of a hole/square hole that starts to limit the frequencies.
http://www.wa1mba.org/WGCalc.htm
The rf loss thru a hole in a metal structure is greater if the hole has a metal tube attached to it.
