Multiple VFD trips on Over Voltage; Stumped!
Hello all,
I've been visiting a facility over the last two days trying to troubleshoot a problem with thirteen 460V 2HP VFDs; package class Deltas. These are very compact, but they do have quite the feature set. When I was first notified of the problem, I was informed that on multiple occasions all of the drives would trip at the same time. First blush is a mains supply issue; transients courtesy of equipment within the facility or a neighboring facility. After personally visiting however, I've found nothing.
What to know:
600' x 1500' facility, typical distribution with 12,470/480 service @ 1200A (estimated). 480 sub feeds to multiple 480 panels with 30 to 45 kVA pad mounts for 208/120. All transformer secondaries are grounded and voltages are balanced.
These 13 drives are all fed from different sub panel locations with the exception of 2 which share a panel.
Each drive is supplied via a dedicated circuit breaker properly sized at 10A per manufacturer's recommendations.
Distance between drive and breaker averages 200 to 250 feet, #12 THHN. Distance between drive and motor is 2 to 3 feet, same #12 THHN.
Everything is solidly grounded.
Drives are rated for 4.2A output, with actual motor loads running at 2.7 to 3.2 depending on location. All motor phases are balanced. All incoming AC voltages are balanced phase to phase and phase to ground.
DC bus levels remain steady be it at idle or at full motor load, centered around 665 (all perfect so far...)
IGBT temperatures are all well below limits according to the HIM modules. (It's been in the mid-90s here)
Yesterday, we verified all drive parameters were sound per the application; no aggresive acceleration, controlled deceleration to stop. DC bus never spiked above 715 when stopping, but that's not when they're having the problem.
Three of the drives were given %5 line reactors, located within 8" of the drives.
Still, suspect of mains supply transients. These drives have a published trip at 810 DC bus or 575VAC equivalent. So, on one of the drive's circuit breakers, I placed a fluke 43B and set it up for 20% transient capture. Throughout the day yesterday, I only captured three events which were each less than 2ms, very low amplitude relative to the normal AC sinewave. The drives all rode through these events while we were there. Before we left for the evening, we cleared the meter memory and started a transient capture again, leaving it there overnight. Went back this morning and was told that all of the drives tripped again at around 8:30AM, even the three drives with line reactors. Checked the meter; nothing captured. Not a one. Before we arrived the supervisors had reset most of the fans, including the one that we were metering. All fans same story, over voltage.
I would have thought that an event large enough to trip multiple drives across multiple sub panel locations would present itself clearly, even for the meager 43B.
So far, I'm just plain stumped. One thing that I'm suspect of, for no real good reason, is the lighting controllers. The facility is lit with these little T5 4 bulb fixtures. The lights are controlled by Lutron remote lighting contactors. These contactors are all co-located to the 480 sub panels. To test them out, we made sure that all the drives were running, then proceeded to start cycling lights on and off. Nothing seen visually, nothing captured on the meter. We also suspected some exhaust fans in the facility, whose feeders are in the same conduits as the drives; these fans are just on motor starters however, and again, no ill effects on the drives when started and stopped. The drives run all day (usually), the exhaust fans run all day, the lights run all day.
Another kicker: sometimes, only two or three drives trip on over voltage, at random times, at random locations.
Could this be a harmonics issue? Could my 43B have missed a cap bank switching upstream somewhere? The line reactors tell me that whatever is happening is in excess of a few ms, but I'm somehow missing it.
What I don't know is if the drives trip while at idle. I've seen drives with load reactors give a false over voltage trip due to output shorts or over current conditions; rapid output shut down spiked the drives backwards through the IGBTs because of the field collapse on the reactor. Removal of the reactor revealed the true fault. Could this somehow be happening to these drives on the input side?
What if I just oversized the drives? Larger DC bus caps may extend ride through times and provide additional buffer?
I didn't see any HF currents on the grounds that I would call excessive. These drives include EMI filters. The MOVs to ground can also be isolated. Not sure what to try next here guys. Could this be a nuisance trip in the HF realm on a periodic basis? What about when they all trip at once?
Reactors were our cheap fix attempt. Isolation transformers at 13 different locations aren't so cheap. New drives? That lands somewhere in between. I've thought about cutting the MOV to ground jumpers; theory being that I've got some kind of circulation there that's reflecting on the DC buss.
Maybe I'm just tired.
Thanks for any inside guys,
~Mark
What to know:
~Mark
RE: Multiple VFD trips on Over Voltage; Stumped!
I'd be tempted to ask your utility when they switch their capacitor banks. My experience is that the chokes usually take care of this problem if it is due to cap switching. Having a bunch of them trip at the same time due to overvoltage sounds like a capacitor switch situation.
We got them to put an air coil inductor down stream of the cap bank, the problem went away. Miraculous!
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
I agree that you really *should* have seen a transient on the 43B, but sometimes the margins are on the wrong side.
Set the 43B to 15 % transient. Then you will probably see it - if it is there - and I am quite certain it is. Have had the same experience as Jeff several times. Utility guys forget what is on the grid and tend to think small when asked about what they got.
Gunnar Englund
www.gke.org
Gunnar Englund
www.gke.org
I got called to a rock crushing plant in the middle of nowhere 2 years ago because almost all of the main motors were tripped off on OL. They have solid state OL relays on everything, so I told them they probably had a phase loss (these plants tend to not have very sophisticated metering / protection systems). They paid me to make the 5 hour drive to get there, I went along a long winding country road with the utility lines strung on the side. I passed an area of burned grass and sure enough, three cables go to one pole, 2 cables leave it, then 3 start up again at the next pole. The 3rd had apparently vaporized at each end and was laying on the ground in the charred area!
When I got to the plant, the utility guys were there swearing to everyone that it wasn't their problem because they were measuring voltage on all 3 phases. I pointed out that they had an asphalt drum mixer running continuously (because it couldn't be shut down) and it was probably acting as a rotary phase converter for the rest of the plant, but only because everything else was off line and the drum was empty. I had taken pictures of the downed line, they quietly got back in their truck and left to take care of it. Turned out that the plant had increased their service from 4000A to 6000A 3 years earlier, but the utility had not increased the cable size feeding them because it was too expensive. They were planning on changing the transformers at each end to use a higher voltage, but that got postponed... for 3 years.
I've never been fond of using a 43B for transient capture, or for any logging for that matter. There are better 3-phase meters that work well for this. I'd expect the "big brother" 430 to do a much better job but I have never used one.
It's definately this one.
I dealt with a site with what, by my measurements as well as 2 other meters, appears to be wrong metering. The utility finally rolled a truck today. When doing other work, I just happened to find the power factor wasn't metered correctly and even though it was brought to the utility's attention at least a month ago, the utility still "wanted more data". I really hope the fix shows a decent savings on the future bills so the customer can go after the utility for compensation due to 10 years of over-billing.
Also the sudden disconnection of a large inductive load upstream of your drives can create a substantial voltage spike.
IF you try to suppress transients some impedance should be in front of the suppressors.
Good luck with your challenge.
If i was still there i'd give ya a hand.
