teeth sprocket design
Hi all,
I want to design with Solidworks (CAD) a sprocket with teeth. Is anybody can suggest me a web site to find the specifications of this type of design.
Thank you
Thank you
RE: teeth sprocket design
I've got some sprockets designed (SW06) for #25 & #41 chain of various tooth numbers.
It's not difficult to do, but takes a bit of time.
I have some tables made up in Excel to make calculating values easier, however these are not used as a Design Table in SW.
"the geometry and mathematics of sprocket design"
Or in the sense of:
"the techniques used to model sprockets in SolidWorks" ?
Adriaan.
I am an Engineer/part time student (Mechatronics) from South Africa.
Advice from lecturer: "Be warned - when you go into industry your boss will give you a thousand things to do and he wants them done yesterday!" So far he is right...
http://www
http://w
http://www.gizmology.net/sprockets.htm
ht
Adriaan.
You still have to put in the hub dimensions, and OD, etc. You can find those dimensions at any manufacturer's site. (Browning, Martin, etc.) The tooth profile is covered though.
James Spisich
Design Engineer, CSWP
+1*
Adriaan.
