Combined plate and grating design
If you have steel grating spanning to two beams (simple span). You then add a steel plate on top also spanning to the two beams. If you already know from the grating manufacture how much concentrated load the grating can take. How would be the best way to analyize the two combined materials with a point load in the center?
RE: Combined plate and grating design
Michael.
Timing has a lot to do with the outcome of a rain dance.
