Adding to Cumulated Dimensions
Is it possible to add more dims to a Cumulated Dimension after it has been produced?
Paul.
RE: Adding to Cumulated Dimensions
Yes.
With the Dimension System Selection Mode toggled or untoggled, select the Cumulated Dimension from the Dimensions section of the Dimensioning tool bar, then select the dimension system to which you want to add the dimension.
TOP MAN!!! The "Expert" here told me that it wasn't possible.
