Adding Teamcenter attributes to the ANT
Hello.  I use an attribute in Teamcenter called "MEUILocation" to create occurrence notes for each unique occurence of a part in a structure.  I'd like to add the MEUILocation attribute to my ANT (similar to turning on Callout) and can't seem to figure out how.  Is it possible?
RE: Adding Teamcenter attributes to the ANT
While I've never done it myself, there are provisions to pass Attributes from Teamcenter back to NX and once an Attribute is in NX, you should be able to show the value(s) of that attribute in a column in the Assembly Navigator.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
When you right click on the column heading in the ANT, go down to Columns --> Configure.
There is an Attribute field at the bottom where you can manually add the name of a Teamcenter attribute to the Column List. Just type it in, and hit apply. It will be added to the bottom of the list, and you can reorder from there.
