Distributed Load - SHELL
I would like to know the way to assign a variable distributed load to a shell element?
RE: Distributed Load - SHELL
you should do the following:
Go to:
Define/Joint pattern/Add new...
Select the shell you want to load, and the go to:
Assing/Joint pattern/
Select the Joint pattern name and specify the function you want for the load (in global axes). Then go to:
Assing/Area loads/Surface Pressure/Click on "by joint pattern"
Select the joint pattern you used before, and the multiplier. Best regards,
Sebastian
