Intersection LOS
Intersection LOS
Intersection LOS
Is it possible, using HCM method or ICU method, to do a proper intersection LOS analysis using ONLY turning counts, and not using any overall through traffic counts?
RE: Intersection LOS
If you have machine counters on all approaches, you could subtract the turning volumes from the total approach volumes to get the through volumes.
Otherwise, I doubt it, unless some math whiz can reduce it to a system of four equations in four unknowns.
     "...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail." - Wm. Phelps Eno, ca. 1928
I don't think it's possible to calculate the LOS without the through volumes.  The individual LOS for each intersection movement is impacted by the through traffic and other turn-lane volumes.
