Abaqus multiple user subroutines
Hi
Sorry for my poor english.
I am using Dflux subroutine, it works well. But now the problem is i that i need to call it many times in diferent Steps with diferent parameters, so i would like to use multiple subroutines, but i dont know how.
How to define in the step which subroutine it should use?
Should it be all subruotines in the same fortran file?
Thank you!
Thank you!
RE: Abaqus multiple user subroutines
How about using an array in DFLUX that stores the parameters you need in the subroutine according to the step number?
I solved with your advice and the -utility routine- GETJOBNAME and some "if's" to control the parameters it should use.
