CA Seismic Principles & Engineering Surveying Exam
Hi
I've applied for the CA PE license by comity but need to take the State test for Seismic Principles & Engineering Surveying.  I'm not too concerned with the seismic portion, but it's been more years than I can to remember since I did any surveying calculations.  Does anyone have any insight/suggestions for this portion of the exam?
Thanks for the replys.
RE: CA Seismic Principles & Engineering Surveying Exam
I had the same questions ten years ago.
Waiting...Waiting...Waiting...
Mike McCann
MMC Engineering
Motto:  KISS
Motivation:  Don't ask
It is extremely hard, I have yet to find a good book to review with, unlike the seismic portion which was a breeze with review books.
I assume you are going to the California SE.  I am saddened to hear that I'll have to study surveying....  Do the surveyors need to pass the PE as well?
dcarr82775
I'm going to get the PE first.  In CA you must be a PE before to can take the SE test.  Per state law a PE can design most buildings (not hopitals & public schools).  Its my understanding that some counties/municpalties require a SE not to mention the some specs also require this.
As for the surveyors having to pass the PE, I'm not sure.
I went into the surveying exam blind and prepared to fail.  However, somehow I passed.  If you have a good handle on geometry and trigonometry along with a bit of common sense it is passable.  Learn how to manipulate sexagesimal angles and understand bearings and azimuths.
I'm sure you'd be more than prepared with the ~$350 kit noted above.
I passed both on the first shot.  Personally, I thought the seismic was easy (we do a lot of commerical buildings in seismic areas)... I spent <20 hrs on that.
I started studying with a bare-minimum survey background.  I knew what an azimuth was, and I had seen US Public Lands stuff before... but nonetheless, the only book I really used was the Cuomo book.  I thought it was great.
http://ppi2pass.com/ppi/PPIShop?ct=SURVEYING&amp;idx=&amp;pr=SPCE2
I also borrowed a textbook from a coworker who had a surveying course, but I didn't really use it.  All said, I think I spent probably 100-150 hours on Surveying stuff... went through Cuomo completely and did all of the sample problems.
Oh, and Good Luck!
I passed the survey on the first try, but the seismic was a bear and took 3 tries. that was 20 years ago, and I do very little structural work and had no seismic background or experience at all. At that time, the pass rate was between 7 - 20% passing. Surveyors take the RLS, not the PE so they don't have any seismic.
Resa Mallahati book was highly recommended for surveying
Steven Hiner workbook is a MUST for seismic
Just passed the California civil PE w/ seismic and surveying - I personally thought that both seismic and surveying were harder than the main 8hr PE exam.  However, there are probably just as many folks out there who would say the opposite.
I agree with westheimer above, that the Hiner workbook is a must for the seismic exam.  That is what I used exclusively to prepare for the test.  My recommendation would be to work every practice problem in that book at least once - a few times would be better.
I thought the surveying exam would be a breeze since I am pretty good with geometry and had worked on a surveying crew during my summers in college - I was wrong!  You get roughly 3 minutes per problem and its amazing how in depth some of the problems are.  I used the triage approach: quickly glance over all the problems at first and assign a 1, 2 or 3 based on level of difficulty.  Work the 1's first, then 2's and 3's for last.  I used the Cuomo book exclusively for preparation.  While I feel it gave a good overview, there were a multitude of questions on CA specific laws and surveying datums that were not mentioned in the book - apparently I was good enough at guessing.  I was most worried about passing the surveying exam after I had taken all 3.
