IA vs IC pipe
IA vs IC pipe
What is the basis for describing pipes as group IA vs IC? For example, looking at ASTM standard spec F1043-06 for industrial chain link fence framework, the Group IA designation is given to 30000psi steel, where the IC is for 500000 psi steel. So the IC has a lower weight per unit length for the same strength. It would seem that IA or IC could be used interchangeably, and the choice might depend upon price. Anti-corrosive coatings seem to be treated separately, so that there, again, it comes down to price, IC not being inferior to IA. ??
RE: IA vs IC pipe
I think you've got the wrong forum.
"We have a leadership style that is too directive and doesn't listen sufficiently well. The top of the organisation doesn't listen sufficiently to what the bottom is saying." Tony Hayward CEO BP
http://www.youtube.com/watch?v=hpiIWMWWVco
"Being GREEN isn't easy." Kermit
http://virtualpipeline.spaces.liv
RE: IA vs IC pipe
RE: IA vs IC pipe
RE: IA vs IC pipe
RE: IA vs IC pipe
RE: IA vs IC pipe
RE: IA vs IC pipe
RE: IA vs IC pipe
RE: IA vs IC pipe
You might get a better answer for chain link fence frameworks in a forum like Metal and Metallurgy Engineering in the Materials group.
David
RE: IA vs IC pipe
Thank you for the straight-up response.
John
RE: IA vs IC pipe
Uniform Guide Specs:
a. Provide posts conforming to ASTM F 1083, zinc-coated. Group IA, with external coating Type A steel pipe. Group IC steel pipe, zinc-coated with external coating Type A or Type B and Group II , roll-formed steel sections, meeting the strength and coating requirements of ASTM F 1043 and ASTM A 702. Group III, ASTM F 1043 steel H-section may be used for line posts in lieu of line post shapes specified for the other classes. [Post shall be either Group IA steel
pipe, Group IC, Group II, roll-formed steel sections, or Group III steel H-sections and be zinc coated (Type A) and polyvinyl chloride coated conforming to the requirements of ASTM F 1043.]
