Carbon Steel to Stainless Steel Flange connections
Is it possible to connect a stainless steel flange to carbon steel flange (24" piping) with river water as the flowing fluid? what type of problem would the flange connection experience? do I need insulating kit? any help would be appreciated
RE: Carbon Steel to Stainless Steel Flange connections
here you can find information on isolating kit:
http://
http://www.corrosionist.com/Galvanic_Corrosion.htm
S
Corrosion & Rust Prevention Control
Thus a bolting and gasket insulation kit is recommended.
Study NACE SP0286 for isolation guidance.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
