Opening a part actually opens dozens! How to stop?
I just opened a part that is a casting in an assembly. Well, I say I did. In actual fact I had to wait over five minutes while it opened assembly after assembly and part after part. Clearly these are referenced in some way. Closing them down was a nightmare too and I ended up shutting down SWX.
I have opened loads of other parts and not had this issue. I have looked to see what I need to change to stop it but am not sure.
Any suggestions?
Any suggestions?
RE: Opening a part actually opens dozens! How to stop?
Good luck.
Jeff Mowry
www.industrialdesignhaus.com
A people governed by fear cannot value freedom.
Dan
www.eltronresearch.com
Dan's Blog
Solution offered up by CBL did the trick. Thanks CBL.
