SW2009 configs
SW2009 configs
SW2009 configs
I feel like I forgot everything I ever knew about SW.
I:
make a feature
dimension the sketch
extrude or rotate
make a new configuration (not dependant)
dbl click feature
edit a dimension
change the config,
and both are the same. The dimension edit affected both configs. Only workaround I've found is to RMB, configure dimension, enter a value, and then the dim is indepenedant across configs. Did I change a default setting someplace? I used to do this all the time, don't remember having to mark a dim like this.
RE: SW2009 configs
In the dimension editor box there is a little dropdown that allows you to select which configs are affected.  "All Configs" is selected by default.
Dan
www.eltronresearch.com
Dan's Blog
