Update 3D geometry
Update 3D geometry
I'm a new in this forum. I have a problem. I prepared a hip joint endoprosthesis model, next I run job and calculated a wear (all procedures are realize in python script), and the next I need to modify (update) the geometry of the waer values, which was calucated, and next I need again run job, and again, again... This is the cycle problem.
Do you have any idea, how I can modify geometry. It's a 3D problem.
Pawel
Pawel
