Turbine trip during run-up
Gents,
We are currently running up a gas turbine that came down on load - about 2.8MW, but it has refused to start. The last time it got to about 50% speed and tripped on high temperature. The control was confirmed ok, but could not decipher what could be wrong. Someone suggested compression leakages but we are not too sure. Does anyone have suggestions on what could be wrong.
RE: Turbine trip during run-up
Isn't there a detailed course of action recommended by the manufacturer of the engine?
TurboTec
blockage at the inlet (collapsed filter elements, etc.).
If all is OK, suggest a borescope inspection of the compressor and hot gas path sections.
TurboTec
50% speed is often the lower limit on speed allowed on the PT (power turbine) before you got an automatic shutdown of the turbine to avoid approaching critical speeds. You should check what your setpoints are in the control system.
Which turbine is it, and what really triggered the shutdown.
I think you want to tell us that the turbine doesn't exceed 50% speed. In this case, the main reason is that the turbine blades were "burned" because of the high temperature (very probably the protection system at high temperature limit doesn't work well). That means the top edges of thie blades are dameged and this will induce a higher level of vibrations than usual level. A boroscope inspection can clarify this problem (I'm agree with TurboTec).
Also, in this case the noise produce by the turbine is different from a normal noise (on low frequencies especially).
Sorry for my english. Its not my native language.
Fernando
