Generator Quad Axis Subtransient Time Constants
Gentlemen. I am between a supplier and a regulatory authority. The Supplier has provided a formula for the above as Tq" = Tqo" x (Xq"/Xq) using a Japanese Society formula. He says the derivation of Tq" is not mentioned in ANSI or IEEE for cylindrical rotor synch generator (air cooled 45MW)
The regulator says that the formula is Tq"=Tqo" x (Xq"/Xq')
( last item is different) which he says is 'extracted from IEC standards'.
Can anyone help with an authoritive reference for this or verify either formula.
RE: Generator Quad Axis Subtransient Time Constants
David Castor
www.cvoes.com
It appears the test procedures in IEEE 519 apply only to direct-axis values, as near I can figure out.
David Castor
www.cvoes.com
