Datum Feature Symbol Help
I am fairly new to Pro/E and I am having trouble figuring out the process for getting reference datums to display in my drawings.  I have defined two datums in my model.  A datum plane "A" on one end of a cylindrical part and a datum axis "B" through the centerline of the cylinder.  The datum feature symbol displays in the model correctly on their respective datums.  When I go to the drawing, the datum "A" is correctly shown on the drawing view, but the datum "B" is not showing up.  I have tried inserting every possible view, along with Show/Erase > show all - to try to get Pro/E to display all datums, to no avail.  Does someone have a nice little tutorial or some helpful hints on this?  Thanks!
RE: Datum Feature Symbol Help
Suggest you ask in the Pro E forum.http://www.eng-tips.com/threadminder.cfm?pid=554
Although, at least to ASME stds you can't make the center-line the datum feature, it needs to be the feature that the axis is derived from.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
If you feel it is necessary to label a centerline as a datum, you need to prefix it with "CL" or "AXIS", thus defining the line as the centerline or axis of datum B.  This should be considered a reference label and you also need to define it elsewhere on the feature.  As noted, simply labeling a line as a datum is not per the standard.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
