thread in drawing section view
why does this happen and how to solve it?
it's a bolt (from standard parts) and a threaded hole.
that hatch over bolt shouldn't be visible.
RE: thread in drawing section view
Are you asking about the hatching?
It does appear to be a bit of a glitch.  Probably to do with how SE is set to process the interference.
You can try right click on view, properties and I think the last tab will have the 'process interference' options - this might fix it though at the expense of more computing power.
Or, maybe try going into draw in view, deleting the default hatching and replacing it.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
thanks for answer.
i already tried "process interference" options, it didn't helped. (anyway it's just a bolt and a nut in a drawing, nothing demanding.)
i'll try with deleting the hatching, but it would be just a workaround. this overlaping shouldn't appear at first place.
