Terminology / N-Type Code Symbol Stamps
Does anyone know of a good website that helps explain the "N", "NA", "NPT", "NS", "NV", and "N3" stamps in regards to when one is used over the next and to refernece further definition under the respective symbology?  Examples would be a great refernece but all I have been able to readily find are basic / brief definitions.
RE: Terminology / N-Type Code Symbol Stamps
Link to and read the following information provided by ASME.....
http://files.asme.org/asmeorg/Codes/CertifAccred/Certification/837.pdf
Most everything can be found at the following link:
http://www.asme.org/Codes/CertifAccred/Certification/Nuclear_Accreditation.cfm
Or perhaps you should attend sone training provided by ASME.
http://www.asme.org/Education/Courses/
Sometimes, a general question begs a general answer
A properly stated question is a question half solved.
