Asign the Name propreties to Elevation. or a point
Is there a solution .... to my problem ?
Im trying to give the name or description to my elevation point ....
Pn : 1
Layer: point
Name: 14.257 = descrition of the point
Loc: 1000 1000
Elev : = (Name) i want it Dynamic the description into my elevation ??
RE: Asign the Name propreties to Elevation. or a point
And did you somehow convey to the reader what program you're using? or what it is exactly that you're trying to do?
TTFN
oups my mistake using terramodel...
trying to give a elevation to my point by using the description someone told me that is possible !?!
I'm not familiar with your program, but aren't all geodetic points characterized by a lat/long/alt of some sort?  Why wouldn't your program have an obvious way of defining a point?
TTFN
im using the description to categorize or sort my point when i sort it ... description = like 15.342 i want all those point at the elevation of the description ...
i want to found a way to reduce my time work ....
at first i work in 2D that why i have X Y and the description but in my 2D i will put the elevation in the description and do what i have to do in 3D ...
surveyorInfo, you are listed as structural, is your request for a steel framing job?
