Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This is a very good site. Please keep it running. Thanks and wishing a great health and success for the site and its owners..."
Geography
KieranSean (Mechanical)
19 Jul 10 9:14
Can anyone advise what tolerance class should be used on the bore of a bore and keyed coupling i.e H8?
Cheers,
Kieran
Helpful Member!  Occupant (Mechanical)
19 Jul 10 9:56
I normally use h7/H8
19 Jul 10 9:58
Above is for Shaft/Bore. Nothing to do with K'way. Your post is confusing.
19 Jul 10 10:03
I know sorry about that. Thanks for the info any way. Much appreciated.
shawnpeter (Mechanical)
19 Jul 10 13:48
clearances for the keyway?
321GO (Automotive)
19 Jul 10 16:37
Do mean BS 4235-1:1972 ?
- Specification for metric keys and keyways - Parallel and taper keys
Good afternoon... can i patend "the wheel" ?
bithkits (Mechanical)
20 Jul 10 5:15
According to DIN: (dimensions in mm)
Length of key (from-to)
Tolerance for key length
Tolerance for keyway length
6-28
-0.2
+0.2
32-80
-0.3
+0.3
90-400
-0.5
+0.5
Hope that helps
Adriaan.
I am an Engineer/part time student (Mechatronics) from South Africa.
Advice from lecturer: "Be warned - when you go into industry your boss will give you a thousand things to do and he wants them done yesterday!" So far he is right...
20 Jul 10 5:18
Forgot to add:
For shafts 10 to 22mm diameter the keyway/key depth tolerance is +0.1mm and it is +0.2mm for shafts 22 to 110mm diameter.
Adriaan.
kingnero (Mechanical)
20 Jul 10 12:25
The width of the keyway is usually a P9 tolerance: the key needs to be pressed in (small rubber hammer will do), and cannot fall out.
juergenwt (Mechanical)
20 Jul 10 14:07
Kieran88 - Find DIN 6880 - bright key steel, dim's and tol..
Square key steel ISO tol. field h9.
For keyways:
DIN 6885 T1, T2, T3
On shaft: Tight fit P9, light fit N9
In bore: Tight fit P9, light fit JS9
Based on ISO Recommendation Nr. 1084 - Rectangular and square keys and their corresponding keyways.
20 Jul 10 16:33
Kieran88 - The above is for the key and keyway only.
If you are looking for the shaft and bore than you need to tell us more about what kind of fit you are looking for (press, sliding etc.).
22 Jul 10 6:52
Thanks for all the advice guys, i should have thought about the thread title as i was enquiring about the bore tolerances in relation to bore and keys.
Would you still use ISO tolerances on imperial shafts and bores?
23 Jul 10 14:05
Kieran88 - yes. Look at your MHB. All ISO Tol. are given in imperial.
Close Box
Join Eng-Tips® Today!
Join Us             Close
