Load Span Tables for 38mm (1 1/2") Wood Plan Deck
Does anyone have a load-span table for 38mm (1 1/2") wood roof plank decking, random length continuous with SPF wood?  I can't seem to find anything for 38mm, all the tables I've found start at 51mm (2").
I have a building with plank decking spanning 6 ft between steel beams.  1 1/2" seems a little on the thin side, but my experience in wood is limited.
Thanks.
RE: Load Span Tables for 38mm (1 1/2") Wood Plan Deck
Actually, one thing I should clarify is that the original design drawings indicated 38mm wood decking.  I'm curious if this 38mm is the REAL thickness, and not the nominal thickness.  For comparison, most 2" wood decks are actually 1 7/16", correct?  Perhaps they specified 38mm as the real thickness, and it's a 2" nominal deck?
38 is the metric equivalent to 2" nominal and is 1-1/2" thick.
Dik
Agree with dikk.  Same as 2", 3", or 4" decking -  Nominal thicknesses for 1.5", 2.5" and 3.5" actual thicknesses.
Mike McCann
MMC Engineering
Motto:  KISS
Motivation:  Don't ask
This should work if you are using 20, 30 or 40 psf live loads.
Garth Dreger PE
AZ Phoenix area
