Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...On your site I feel quite confident that the contacts and feedback will make my life a little less hectic..."
Geography
kafeel (Aeronautics)
22 Jul 02 12:23
Hi!
I am trying to generate turbulence in a wind tunnel (1148mm X 814mm). I need longerlength scales(longitudenal) at lower turbulence intensities. I have used typical grids with the ratio of spacing to teh bar thickness being 4 and 5. I have tried bars as wide as 400mm. the max. length scales I could achieve was 0.11m . According to Vickery the max. length scales cannot be longer than 13% of the width of the tunnel, that would mean a max. of 0.15m length scales, however I havent been able to achieve this.
The turbulence has to be uniform across the cross section.
I am using Hotwire annemometry for analysing the flow properties. the length scales are found by matching the spectra with the von'karman spectra (length scale being the variable parameter).
Thanks in advance
Close Box
Join Eng-Tips® Today!
Join Us             Close
