Gas Blowby case
Gas Blowby case
I am trying to calculate the gas blowby case flowrate from high pressure separator to low pressure separator. I am wondering if I can use the max Cv of the liquid level control valve.
The Cv by definition is the related to the flow rate of water at 1 psi pressure drop. In gas blowby case we try to find the gas flow rate. By this definition of Cv, Is it applicable to gas flow calculation??
Sav
Sav
RE: Gas Blowby case
RE: Gas Blowby case
Sav
