Units: mm & inch in the same model
Hi all
The company that I work for uses metric and imperial units in the same drawings. For instance, they use mm (metric) for flanges, and inches (imp) for pipes. And they like to see this on their drawings.
Is there a way to quickly switch between the two units? I'm having to go into doc properties every single time.
thanks
thanks
RE: Units: mm & inch in the same model
http://mad4cad.com/m_units_hlp.php
Could you just set your drawings to dual units?
- - -Updraft
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Thanks Updraft & ctopher, I'll try it that ways as well.
