Solidworks API change Part transparency
Hi All -
I'm trying to make a macro to toggle the transparency of a part.
I'm having trouble editing Solidworks' example:
ht tp://help. solidworks .com/2010/ English/ap i/sldworks api/Make_P art_Transp arent_Exam ple_VB.htm
This example is great, except:
() I want to leave the colors of the faces alone instead of setting them all to an explicit value.
() I'd like the macro to toggle transparency between two values (say, 0% and 50%) when I run it.
Help??
Code Below:
This example shows how to make a part transparent.
' Preconditions: Part is open.
' Postconditions: Part is now transparent.
Option Explicit
Public Enum swUserPreferenceIntegerValue_e
swDocumentColorShading = 185
End Enum
Public Enum swBodyType_e
swAllBodies = -1
swSolidBody = 0
swSheetBody = 1
swWireBody = 2
swMinimumBody = 3
swGeneralBody = 4
swEmptyBody = 5
End Enum
Function GetRValue(MyColour As Long) As Long
GetRValue = MyColour Mod 256
End Function
Function GetGValue(MyColour As Long) As Long
GetGValue = (MyColour \ 256) Mod 256
End Function
Function GetBValue(MyColour As Long) As Long
GetBValue = (MyColour \ 65536) Mod 256
End Function
Sub main()
Dim swApp As SldWorks.SldWorks
Dim swModel As SldWorks.ModelDoc2
Dim swPart As SldWorks.PartDoc
Dim nDefaultColour As Long
Dim vBodyArr As Variant
Dim vBody As Variant
Dim swBody As SldWorks.body2
Dim swFace As SldWorks.face2
Dim nMatProp(9) As Double
Dim vMatProp As Variant
Dim bRet As Boolean
Set swApp = Application.SldWorks
Set swModel = swApp.ActiveDoc
Set swPart = swModel
nDefaultColour = swModel.GetUserPreferenceIntegerValue(swDocumentColorShading)
Debug.Print "File = " & swModel.GetPathName
Debug.Print " Default Colour = RGB(" & GetRValue(nDefaultColour) & ", " & GetGValue(nDefaultColour) & ", " & GetBValue(nDefaultColour) & ")"
' Set to sensible defaults
' Grey for default colour
nMatProp(0) = GetRValue(nDefaultColour) / 255# ' red
nMatProp(1) = GetRValue(nDefaultColour) / 255# ' green
nMatProp(2) = GetRValue(nDefaultColour) / 255# ' blue
nMatProp(3) = 1# ' Ambient
nMatProp(4) = 1# ' Diffuse
nMatProp(5) = 1# ' Specular
nMatProp(6) = 0.31 ' Shininess
' Increase transparency
nMatProp(7) = 0.95 ' Transparency
nMatProp(8) = 0# ' Emmission
vMatProp = nMatProp
vBodyArr = swPart.GetBodies2(swAllBodies, True)
For Each vBody In vBodyArr
Set swBody = vBody
Set swFace = swBody.GetFirstFace
While Not swFace Is Nothing
swFace.MaterialPropertyValues = vMatProp
Set swFace = swFace.GetNextFace
Wend
Next
' Redraw to see new transparency
swModel.GraphicsRedraw2
End Sub
ht
Help??
Code Below:
Option Explicit
End Enum
swAllBodies = -1
swSolidBody = 0
swSheetBody = 1
swWireBody = 2
swMinimumBody = 3
swGeneralBody = 4
swEmptyBody = 5
End Enum
End Function
End Function
End Function
Sub main()
Dim bRet As Boolean
vMatProp = nMatProp
Set swBody = vBody
Wend
Next
End Sub
