ASME B46.1 - Roughness Standard
Can anybody help me to find the ASME standard;
ASME B46.1 - 1995 (Revision of ANSI/ASME  B46.1-1985) Surface Texture (Surface Roughness, Waviness, and Lay) for a scientific search?.....
RE: ASME B46.1 - Roughness Standard
You can obtain ASME standards from a number of places, including the following:
ASME International  http://www.asme.org/
Global Engineering Documents  http://global.ihs.com
On a related note, does anyone out there know of a roughness standard for polished surfaces?  Does one just specify what grit to use for the final pass?  For example, a polished brass bell may have a satin finish, mirror finish, or something in between.  Is there a standard I can specify?
Thanks in advance,
Mike
