Points from file
Points from file
Is there any tool that creates a set of points from a file? I am currently trying to create a set of around 16 points on a curve that are not uniformly spaced along this curve and had the thought that since I have the location of these points maybe I could just read in a file to place the points instead of having to create them 1 by 1
Jacob
Jacob
RE: Points from file
http://www
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
John - not in this case. I have a set of points, and actually I want both a curve and points from this set so I can place datums at each of the points on the curve.
Upon rereading what you ACTUALLY asked for, ewh's approach, sans the deleting of the spline, would give you what it would appear you are looking for.
And as a way to get you started, attached is a file which you can use to create a spline using the Spline from File of Points method. Note that the format of this file documented in the help files (what looks like an extra field of data is an optional way of including slope control to the process, but is not mandatory).
And before you ask, you will need to create separate files for each curve being created.
John R. Baker, P.E.
Industry Sector
Cypress, CA
