anyone have exp on in Systems Engineering?
I was hoping someone who has some personal experience with this can chime in and possibly lead me towards the right direction.
I have a background in Mech and I've been looking into a MS in Systems Engineering recently. From what I've read, it sounds like its something I want, as it seems like dealing with the bigger picture in terms of a whole engineering project. Additionally, it is becoming a very sought after degree in the defense industry in the up coming decade. Another reason is that I'd like to live in the DC area.
I did some job listing searchings for system engineering jobs in my company, and it appears that nearly 95% of them seem to be an extension of CS degrees and in the IT field, and very few that that accepted just a Systems Engineering degree.
With that said, i'm kind of wondering if I'm just not doing a good job finding the right Systems Engineering jobs, or if it is what it is and I'm just looking in the wrong area.
RE: anyone have exp on in Systems Engineering?
I have yet to do a significant amount of systems work.
The term 'systems' gets applied to all kinds of things, a lot of them related to IT, rather than the kind of systems engineering I studied.
That said, we do have at least one fairly prolific poster on here that does systems engineering in defense, so hopefully he can chime in.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Pretty amazing guy with a very accomplished resume'
Systems can be Requirements Integration, which basically takes the requirements documents and break down each one into actual requirements. You then create your own "derived requirements" and show how they meet the program level ones. Once your derived requirements are set, you use test data to show you meet those.
The other side of Systems is the inspection based side. You have a systems level hazard analysis, which is broken down to the part where the FMEA is performed. Your FMEA controls the inspections on the part to cover the Failure Modes of the critical parts. These can be passed onto the suppliers, or it can be government buyoffs.
Outside of all of this, there is Process FMEAs which break down any specific process into processes...FMECAs which assign a probability to failure modes...
Systems E can be used to track deliverables within a specific project, like Test Readiness Reviews.
Every defense contractor will have jobs like this. I was hired to Lockmart as a Systems Engineer, but until I got transfered I never really did it. They mirror the government and NASA as far job titles/structure.
I think you need to look at Systems Safety instead of Systems Engineering since that implies IT.
Doing a search on LM's job site for safety systems, i did get 1 result for a systems engineering job that fits the type of Systems Engineering we're discussing.
Doing a search through my company (defense contractor similar to LM), that term does not appear anywhere, however I believe i did find the positions that I'm looking for. Would terms such as "Operations Research", "Industrial Engineering", and "Process Analyst" be key terms? Their job descriptions seem to fall into the type of Systems Engineering that we are talking about here. Some of them also state "Systems Engineering degree".
One concern I have now is how readily available these system engineering jobs are for a fresh MS Systems Engineering grad, with a few years of exp in sub-system engineering.
looking on USAjobs, industrial engineers fit the job description of the systems engineers we're talking about here.
