HELP plastic cracking/breaking HELP
Team
I'm a rubber eng, but i have to do an analysis on a plastic cracking/breaking
The FTIR concludes the presence of an Oil similar to Castor Oil or Tall Oil.
There is a plastic casing an a wire wrapped comming inside of the casing.
Any idea or where does it can came, Wire wrap, plastic case....
RE: HELP plastic cracking/breaking HELP
"There is a plastic casing an a wire wrapped comming inside of the casing. "
Maybe a picture would help, as that description just doesn't work for me.
"Any idea or where does it can came, Wire wrap, plastic case.... "
Ok, please translate that into English? :) Again, a picture would help.
And you might get more help on plastics...in a plastics material forum?
Another possibility, post production. It could be a lube used on a secondary assembly machine or process.
Failing that, maybe one of your operators has greasy hands.
