Canadian Building Code
I'm doing some preliminary design for a building in Canada, and I am not familiar with the Canadian Code. I'm having difficultly with two items:
1. Snow load: In Part 4 of the 2006 Building Code,there is a Ca (shape factor) applied to the snow load that is equal to 1.0, except for drifting/sliding snow areas, valleys, at roof projections, etc. However, I can't find anything about calculating Ca for these exceptions. My interest is in drifting/sliding snow. How do you calculate drifts for the Canadian Code?
2. Wind load: 4.1.7 tells you how to calculate external & internal pressures and suctions, but it is unclear to me how you combine them for the building as a whole (MWFRS), for primary members, and for components. When I add the external and internal numbers, I get very large pressures, and the wind pressure for my particular city is q = 0.54kPa, which equates to only about 65 mph. The key seems to be 4.1.7.1(2) and 4.1.7.1(3), but I can't make heads or tails of it.
Any insight or a design example from somebody who is familiar with the Code would be greatly appreciated.
RE: Canadian Building Code
Do you have the Commentaries on the NBCC or just the NBCC itself? Both of these are addressed in the Commentaries.
Both your questions are addressed in the Users's Guide - NBC 2005, Structural Commentaries prepared by the National Research Council of Canada. As there are many different scenario's, likely best if you pick up a copy.
Thanks to both... just what the doctor ordered! I was unaware of this document.
