ASME Filler Metal Classifications
Where can I find a chart depicting F numbers for Stainless steel GTAW wire. i want to verify the ER308, Er308L, ER316, ER316L, Er309, ER309L and ER304, Er304L, etc... all come from the same F No. grouping....I believe its F-6...Thanks for the help!
RE: ASME Filler Metal Classifications
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
Steve Jones
Is SFA 5.9 an ASME code? If so what section?
SFA 5.9 is in the ASME Code, Section II. I'll let you do the rest and figure out which part.
There is no conversion from ER316 tp ER308, they are two distinctly different filler metals. Not sure what you would mean by that question.
The F #'s come from ASME Sect IX.
The A #'s are 'puddle analysis'of a specific filler, and you cross-reference between IX and the fillers metallurgy --from IIC.
Until you have done all this a time or two, it's tough.
