GD&T Positional tolerances
Can you have a positional tolerance feature control frame on a hole without referance to any datums? If this is a correct way of dimensioning, then what is it controling? Perpindicularity, hole to hole, something else?
RE: GD&T Positional tolerances
forum1103: Drafting Standards, GD&T & Tolerance Analysis might get you more answers.
I had a quick look in 14.5 and a simple answer didn't jump out at me, so maybe I'll leave this one to others unless I get a bolt of inspiration.
I'd normally expect at least a single datum called out to give perpendicularity but like I said, didn't find a concise explanation in a quick flick through section 5.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Kenat is right pointing you to the other forum.
As to your question, I see no purpose of a positional tolerance unless it is relative to something.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
I agree with the above posts,  there is no reason to put a positional tolerance on a hole with no datum refrence unless the hole itself is the datum.
