Increase number of results
When I run ANSYS model this error massage is coming. "Number of results on results file exceeds maximum of 1000,maximum may be increased with /CONFIG command" How can I do this without writing commands, I mean using ANSYS main menu or utility menu? Please help me.
RE: Increase number of results
What you can do is decrease the number of results to be writen.
Analyse Settings-->Output Controls-->Calculate Results at--> Equally Spaced Time Points.
Otherwise you will need to increace the number of results with the /config command.
