How to copy sketch geometry
How do you do to copy sketch geometry from one plane to another plane in the same model file ? Do you use blocks or other issue ? Thank you
RE: How to copy sketch geometry
Pick the Sketch and Edit Copy, Edit Paste to another plane... or Window select the sketch and Edit Copy, Edit Paste.
Scott Baugh, CSWP pc2
Berry Plastics
Cad Admin\Design Engineer
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
I'm always leery of "convert entities"... it seems to bog things down and is prone to dangle.  I'll trace over the seed sketch if it is a onetime thing, if it is repeated I'll go with a block.
I may also ctrl-drag the sketch from the feature tree to the plane.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
block is my fav..
