Deflection of laterally loaded piles
Does anyone know of an equation(s) to use for determining the ground surface deflection of a pile that is laterally loaded?
I know of M.T. Davisson's work from 1963, but are there any others that I could use for comparison?
http://www.spiraleng.com
RE: Deflection of laterally loaded piles
Maybe Evans and Duncan 1982. These are charts though, I believe.
If deflection calculations are important, I recommend a soils report.  And then you will need the proper software to assist you.  As BigH's formulas show, this is complex.
I believe that LPile can do this.
Mike McCann
MMC Engineering
Motto:  KISS
Motivation:  Don't ask
