Attach a GDT Feature Frame to a Note
How do I do this?
RE: Attach a GDT Feature Frame to a Note
Move both to position, select both, right-click, select 'group'.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Or you can have the note highlighted when you invoke the GTOL command and the frame will be automagically attached.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
I tried this but they won't group. For kicks I tried to group two GDT frames(not what I want to do)and I can do this but I can't group a Note to a GDT frame.
I just tried grouping and it worked fine. Using SW 2010 here. While editing the note, you can select the GTOL frame from the properties manager and have it attached that was as well.
Jeff Mirisola, CSWP
M9 Defense
My Blog
Jeff, also using SolidWorks 2010. Have service pack 4 installed. I tired closing SolidWorks and restarting but I still can't group a Note and a GDT frame together. The Group icon is grayed out.
That's weird. I can't think of what would cause the option to be grayed out.
Jeff Mirisola, CSWP
M9 Defense
My Blog
Works for me also. Hold down Ctrl key and select both, then group.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
make sure the GD&T frame is part of the same view as the note.  If on different views (or one on the sheet) group doesn't work.  Use "lock view focus" the ensure.
-Dustin
Professional Engineer
Pretty good with SolidWorks
Dustin is all over it! Needs to be in the same view.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 3.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
They are in the same view. Going to call our VAR GoEngineer today.
